As the title says...I have a 2007 500 X2 that I purchased new. Machine has about 400 hours and 2000 miles of pretty hard utility and trail riding use. I've had my share of problems including an exploded front gearbox last summer (replaced with a non-ADC unit) and now this:
Just did my spring service including oil change with Amsoil 0-40 which I have used since new. When I drained the oil tank, a tablespoon of clear water came out followed by milky oil. I also drained the crankcase and got milky oil. My coolant has never been changed, and the level remains the same as when I got it from the dealer. All the vent hoses and everything else seems pretty normal. No exernal leaks at all.
Could all this be condensation?! I change my oil every 6 months or so, so who knows how long this water has been in there. I have really not been doing any deep water riding at all. Anyone else have this problem? After the oil change it started right up and seemed to run normally with no smoke so hopefully I got out of this without engine damage, but I guess I'll never know for sure. I'll do a compression test next time I go out there...what else can I do to suevey the engine's condition?
Pretty dissappointed with this latest problem. I obsessively maintain my stuff so I sure hope this hasn't done permanent damage. I really like this machine as it is the only one out there with the utility of a dump box and 2-up capability (both features I use regularly)
Thanks for any help,
keep a close eye on coolant level, if its not losing any, than water had to come from outside source, I think I would change it again in a couple hours and see if there is more or if you got it all
Do as Russ C recommends keep an eye on the coolant level.
Thanks for the replies...
I check the coolant level all the time...hard not to since it's right there. I put a piece of electrical tape at the level to be sure this time. I seriously doubt this is coolant, but can't hurt to be extra careful.
Had to go back to work and won't be home for a week, so when I get back I'll take it for another good ride, change the oil again and do a compression test.
Hope I got out of this easy...hard telling I guess. Wasn't really ready to trade for another machine yet, but this does get me thinking about it.
Thanks again
Yep...not sure how I overlooked that one, but I'll be sure to check just to be certain.
I did read another thread about a guy who had one of these machines and the same problem. Turned out to be condensation and it actually separated and froze at the bottom of his tank, starving the motor of oil the next time he used it. Worst part is that after it separates and freezes, the dipstick would read nice clean oil!
Certainly hoping this didn't happen...especially since we are coming out of winter in Maine, so it is possible. That's a lot of condensation, but their theroy was that the machine was used for short trips and never warmed up much in the winter and the external plastic oil sump was more suseptable to fast temperature changes. Sounds possible.
Hoping my high priced amsoil saved the day no matter what happened...
Thanks for the help.
Yep, I seen the condensation deal as well. They (Polaris) actually cut the rubber breather tube at one point so the oil tank wouldn't blow. I've never seen one blow but have heard and seen pics.
BTW - I'm not sure about your 07 but the 500's hadn't changed forever so a compression test my not work for you. I'd hate to see you test it and take a fit when it shows low:) They use to (I assume still do) have a built in decompression on the cam. You need to perform a leak down test if you're concerned. Someone correct me if I'm wrong.
Discussion Starter #8
Ok, this is really good to know! Leakdown test sounds like a good idea. Does anyone have a compression spec for this motor or do we know if it has an auto decompression like the older models?
Funny you should mention the ancient 500 motor deisgn...this is one of the reasons I bought this machine. I know this is a tough motor and probably is why it can handle the abuse from the dumb Polaris oil sump design at all.
Overall, I think Polaris does a pretty good job with their ATV's but there are some major systems that need updating and I've now had two major problems with both of them (Front gearbox and oil sump design).
Thanks very much for all the help...this forum has been great!
What type of clutch kit are you using? Thinking about getting one.
