2007 Sportsman 500HO EFI fault codes
5.3K views 2 replies 2 participants last post by  opposite2
I am having some fault codes with mine, code 41.22,55 and the tach will work for a few seconds with the numbers going up ,when letting off the throttle the numbers count down to zero & doesn't register anymore. How can I clear the codes or how to fix the issues ? I disconnected the battery for 20 minutes or so & still have the same codes.
thanks for any help with this.
#2 ·
So you have some damaged wires. 22=throttle position sensor wires, 41=T-BAP wires are bad, and 55=diagnostics light wires are bad.
