Have 6 different codes for this machine, codes 22,41,45,46,47,55, can all of these be related to wiring issues, sensors, or is the ecm needs to be replaced ? Sometimes the quad runs fine for awhile, other times then it acts up with running rough & sometimes back fires. anybody run into this issues with their Sportsman with so many codes ?
Yes your harness is jacked. Start pealing the loom back along the center, top, left side and look for the damaged wires.
Sounds like a major project, I did replace the TPS & the Barometric pigtail, sounds like I have to dig deeper into the harness, thanks for the reply back. I just find it hard to believe that all my issues are wiring issues, but if you had the same issues & fix them the weekend sounds like a good time to check them.
