1 - 1 of 1 Posts
6x6 SPECIFICATIONS
Engine
Engine Type 4-stroke
Displacement 499 cc
Carburetion 34mm CV Mikuni
Cooling Liquid
Starting Electric w/ recoil backup
Drivetrain
Final Drive Shaft/Chain
Transmission R/N/L/H
Drive System Automatic PVT
EBS (Engine Braking System) Accessory
Suspension
Front Suspension MacPherson strut with 6.7/17 in/cm travel
Rear Suspension Progressive-rate center swing arm w/ 6.5/16.5; rear swing arm w/ scissor stabilizer w/ 7.5/19.1 in/cm travel
Brakes
Front/Rear Brakes Single-lever hydraulic disc w/hydraulic auxilary rear hand brake
Tires/Wheels
Front Tires 25 x 8 - 12
Rear Tires 25 x 11 - 10
Wheels Steel
Dimensions/Capacities
Wheelbase 77/195.6 in/cm
Turning Radius (inside tire) 119/302.3 in/cm
Dry Weight 895/406 lbs/kg
Length/Width/Height 105/46/48, 266.7/116.8/121.9 in/cm
Seat Height 34/86.4 in/cm
Fuel Capacity 4.25/16.1 U.S. gallons/L
Front-Rack Capacity* 75/34 lbs/kg
Rear-Rack Capacity* 800/362.9 lbs/kg
Hitch Std / Drawbar
Hitch Towing Capacity* 1500/680.4 lbs/kg
Braked Trailer Towing Capacity 2,506/1,137 lbs/kg
Hitch Tongue Weight* 150/68.2 lbs/kg
Ground Clearance 5.5/13.9 in/cm
Instrumentation/Features
Gauge Type Digital
Speedometer/Odometer Standard
Tripmeter Standard
Hourmeter Standard
High-Beam Indicator Standard
Gear Indicator Standard
Warning Lights Hi Temp / Low Battery
DC Outlet Standard
Colors
Colors Sportsman Green/Black
MSRP (US$) $7,999
1 - 1 of 1 Posts
