1 - 2 of 2 Posts
700 EFI SPECIFICATIONS
Engine
Engine Type 4-stroke
Displacement 683cc Twin
Carburetion 40mm Throttle Body
Cooling Liquid
Starting Electric
Drivetrain
Final Drive Shaft
Transmission P/R/N/L/H
Drive System Automatic PVT
EBS (Engine Braking System) Accessory
Suspension
Front Suspension MacPherson strut with 8.2"/20.8cm travel in/cm
Rear Suspension Fully independent, progressive rate with anti-roll bar; 9.5"/24.1cm travel in/cm
Brakes
Front/Rear Brakes Single-lever hydraulic disc w/ hydraulic rear foot brake
Tires/Wheels
Front Tires 26x8R12; PXT
Rear Tires 26x11R12; PXT
Wheels Steel
Dimensions/Capacities
Wheelbase 50.8/128.9 in/cm
Turning Radius (inside tire) 76/193 in/cm
Dry Weight 748/339.3 lbs/kg
Length/Width/Height 83x48x48 / 210.8x121.9x121.9 in/cm
Seat Height 34/86.4 in/cm
Fuel Capacity 4.13 / 15.6 U.S. gallons/L
Front-Rack Capacity* 100/45.4 lbs/kg
Rear-Rack Capacity* 200/90.7 lbs/kg
Hitch Std / Receiver
Hitch Towing Capacity* 1500/680.4 lbs/kg
Braked Trailer Towing Capacity 1,913/868 lbs/kg
Hitch Tongue Weight* 150/68.2 lbs/kg
Ground Clearance 11.3/28.6 in/cm
Instrumentation/Features
Gauge Type Digital
Speedometer/Odometer Standard
Tachometer Standard
Tripmeter Standard
Hourmeter Standard
High Beam Indicator Standard
Gear Indicator Standard
Fuel Gauge Electric
Warning Lights Hi Temp / Low Battery
Rear Work Lights Accessory
DC Outlet Standard
Winch Pre-Wire Standard
Colors
Colors Green/Black; Black/Silver; Red/Black
MSRP (US$) $7,699
1 - 2 of 2 Posts
