I bought a 2007 Sportsman 800 a month ago with a broken cage in the front differential. I pulled out the differential and replaced the cage with a new Polaris part. I filled the differential with Polaris fluid, but it's not operating right. Both front wheels kick in perfectly in AWD. When I let off the gas with the switch in AWD, the handlebars jerk to the left like the left front wheel is engaging. Any ideas what the problem would be? Thanks.
Did you also replace the armature plate? If the armature plate was warped or damaged at all when the cage broke, it will cause engagement/disengagement issues.
