noticed some play on my u joints on my 2007 polaris 800 ,how do you check u joint to see if they need replacing thanks
Discussion Starter #2
i notice some play when grabbing front shaft on ujoints and also rear ujoint shaft .should there be any play .looked like yoke was possibley loose
The yokes will have some play on the shaft. You'll need a bright light and hold the yoke while wiggling the joint up/down side to side and then rotating back and forth. You have to look real close while wiggling to be able to tell the difference between slack in the shaft splines vs. play in the joint itself.
If you need to replace them, get joints that can be greased.
