recently picked up a 07 sportsman 700 with 500 miles on it. could hear a small clunk coming from by my right foot. just changed all fluids so i know they are full. the drive shaft that goes from the transmission to the front diff had slop in it on where the yoke slips onto the transmission out put shaft. is this normal slop or do i need a new yoke?
here is a video of the slop
Is there a grease fitting in there? I would def change the u joint! Worn and dry! Play on left (pumpkin and shaft) is ok but should be a grease fitting
The play in the yoke is and looks normal. There should be a grease fitting on the yoke going to the tranny. It's hard tell but there does seem to be play in the u-joint. I would replace the u-joints and grease that zerk on the yoke.
