Hello, I have an 2007 Polaris sportsman 500 I acquired from my father in law. Well had it running then it just died and drained the battery out on the trails. Changed the battery and can’t get any power, the winch doesn’t even work. No power to the dash lights or nothing when I turn the key, changed out the stator but I don’t think that has anything to do with power...can’t find any fuses and kill switch is on so the bike can get power idk what else to look for maybe a fryer ecm or power distribution box???
I will presume it an EFI model
Right off the battery is a fusible link - check the orange wire at the key switch for 12v - if power there, check for 12v on the red/blk wire at the LH handlebar switch - if no power on the orange wire, check for 12v on the red wire at the SSCB (control module) - if 12v on the red wire, replace the SSCB module - if no power on the red wire, tighten the battery terminals, replace the battery or replace the fusible link.
fusible link is where my money is being put on!!!!!!!
