1 - 2 of 2 Posts
Installed a new motor in my 2007 sportsman 500 HO efi. The motor I installed ran when I bought it and now will not run. After doing some testing I found that the fuel pump is not getting any power. I took a test light and check the plug in for the fuel pump and wasn’t able to get any sign of power coming through the wires going to the fuel pump. Any ideas on what could be causing this issue?
I’m also having issues removing the right front axel. I’ve tried pulling straight out with no success as well as tying a strap to the front of the axle by the housing and pulling straight out with no success.
Since you changed engines, it's most likely a connection ahead of a failed component - maybe as simple as a faulty ground - recheck all the connections and then get a dealer to diagnose the problem - it may be the ECU or SSCB - one is $550 and the other is about $500
1 - 2 of 2 Posts
