Have an 08 Sportsman 400 HO. AWD did not work when I got it. Took apart and found the thrust button assembly was missing? Think it just wore down and got ground up. Anyway, bought a new one, inspected everything and all looked fine otherwise. I wasn’t sure how tight to make the thrust button so I just turned the Allen screw until it was snug after re-assembly. Put it back together and still no AWD. I get 13V at the plug with the AWD switch on and I get 23-24 ohms on the coil when I test it. Any ideas as to what else I should check? Can’t find much info on this machine on any forums. Any help would be appreciated!
Well it sound electrically good. Coil pulling in the sprague?? The cage move freely??
No clicking. Doesn’t do anything when I flip switch to AWD and give it gas in gear up on the stand.
Ground on the harness good??
How would I check that? Continuity between ground and one of the pins feeding coil?
Yup the pin that doesn't have the 12vdc.
Sounds like its mechanical inside the diff. Hows the fluid look?
Put in new fluid when re-asseambled. Wondering if I put the armature plate in backwards. Thinking I may have put the nubs that grab toward the bearing vs inside the back of the gear. Is that possible?
