wondering if anyone had service manual for this or info on which wires i need to use to wire up hand warmers?i see a couple sets of wires under speedometer but not sure which to use?
thanks
The orange/white is power with the key on, and you just ground the brown wire from the warmers to something metal inside the pod. Very easy to install.
You can also tap the hot wire off the accessory plug and save the other for something else.
I cut the spade terminals off the power outlet, combined the hots and grounds and crimped 2 new spades then just plugged it back into the power outlet. The less connections in the wiring the better!
You could run both down to the fuse block area under the radiator cap access panel... "Hood".
My pod grounds are #8 ring terminals under the torx screw on the fuse block mount.
Power to one of the two ignition accessory wires... orange / white stripe with heatshrink covering an unshielded 1/4" female quick disconnect. You may need to clip the end of the shrink back to the connector tip to plug into it. Use a shielded 1/4" male to mate.
Sent from my AT100 using Tapatalk 4
