21 - 22 of 22 Posts
Discussion Starter #21
OK - do you have a service manual?
I do not have a manual for the 08 Outlaw 50, but I have one for the Predator 50 - they use the same engine - if you want a copy message me an email address and I'll send you a PDF copy.
i just downloaded one thanks for offering
Discussion Starter #22
latebird here's where were at last night did compression check again with thottle open spinning with the starter went to 100-105 range. (the kick start is broke) remember i said it wouldnt disengage the starter so i took the to starter bolts out got it spinning and wala it fired up and went to a nice idle. i appreciate your tip on the compression. i was going to tear it apart. so now i need to fix the kick start it look like that little one way gear is wore out and figure out why the electric starter wont disengage. also inspecting the clutch i can grab it and wiggle it back and forth almost like a bearing is wore out? thanks for the help!!!
21 - 22 of 22 Posts
