1 - 1 of 1 Posts
Specifications
Polaris Phoenix Engine
• Starter : Electric / Kick
• Compression Ratio : 9.2:1
• Displacement (cc) : 196
• Engine Stroke : 4-Stroke
• Cylinders : 1
• Engine Type : Single-Cylinder
Polaris Phoenix Transmission
• Reverse : Yes
• Primary Drive (Rear Wheel) : Shaft
• Transmission Type : Continuously Variable (CVT)
Polaris Phoenix Weight
• Dry Weight (lbs) : 395
• Towing Capacity (lbs) : 300
Polaris Phoenix Dimensions
• Height (in) : 42
• Wheelbase (in) : 45
• Ground Clearance (in) : 5.7
• Width (in) : 42
• Length (in) : 65
Polaris Phoenix Driveline
• Rear Unlocking Differential : No
• Driveline Type : 4X2
Polaris Phoenix Capacities
• Fuel Capacity (gal) : 2.5
Polaris Phoenix Front Suspension
• Front Travel (in) : 7
• Front Suspension Type : Double A-Arm
Polaris Phoenix Rear Suspension
• Rear Travel (in) : 6.5
• Rear Suspension Type : Swing Arm
Polaris Phoenix Seat Specifications
• Seat Height (in) : 32
• Number Of Seats : 1
Polaris Phoenix Brakes
• Rear Brake Type : Drum
• Front Brake Type : Dual Hydraulic Disc
Polaris Phoenix Tires
• Rear Tire (Full Spec) : Maxxis 20 X 10-9
• Front Tire (Full Spec) : Maxxis 21 X 7-10
Polaris Phoenix Price
MSRP : $3199
Warranty (Months) : 6
1 - 1 of 1 Posts
