1 - 2 of 2 Posts
Specifications
Polaris Sportsman Engine
• Starter : Electric / Pull
• Compression Ratio : 9.8:1
• Displacement (cc) : 455
• Engine Stroke : 4-Stroke
• Cylinders : 1
• Engine Type : Single-Cylinder
Polaris Sportsman Transmission
• Reverse : Yes
• Primary Drive (Rear Wheel) : Shaft
• Transmission Type : Continuously Variable (CVT)
Polaris Sportsman Dimensions
• Height (in) : 45.5
• Wheelbase (in) : 46
• Ground Clearance (in) : 9
• Width (in) : 45
• Length (in) : 72
Polaris Sportsman Driveline
• Rear Unlocking Differential : No
• Driveline Type : Selectable 4X2 / 4X4
Polaris Sportsman Capacities
• Fuel Capacity (gal) : 4.5
Polaris Sportsman Front Suspension
• Front Travel (in) : 7
• Front Suspension Type : McPherson Strut
Polaris Sportsman Rear Suspension
• Rear Travel (in) : 8
• Rear Suspension Type : Independent
Polaris Sportsman Seat Specifications
• Seat Height (in) : 33
• Number Of Seats : 1
Polaris Sportsman Brakes
• Rear Brake Type : Hydraulic Disc
• Front Brake Type : Hydraulic Disc
Polaris Sportsman Weight
• Dry Weight (lbs) : 598
• Towing Capacity (lbs) : 750
Polaris Sportsman Tires
• Rear Tire (Full Spec) : 24 X 11-10
• Front Tire (Full Spec) : 24 X 8-12
Polaris Sportsman Price
MSRP : $5599
Warranty (Months) : 6
those things look so small now that i have the 850 :)
1 - 2 of 2 Posts
