Specifications
Polaris Sportsman Engine
• Starter : Electric / Pull
• Compression Ratio : 9.78:1
• Displacement (cc) : 683
• Engine Stroke : 4-Stroke
• Cylinders : 2
• Engine Type : Twin Cylinder
Polaris Sportsman Transmission
• Reverse : Yes
• Primary Drive (Rear Wheel) : Shaft
• Transmission Type : Continuously Variable (CVT)
Polaris Sportsman Weight
• Dry Weight (lbs) : 860
• Towing Capacity (lbs) : 1500
Polaris Sportsman Dimensions
• Height (in) : 48
• Wheelbase (in) : 57
• Ground Clearance (in) : 11
• Width (in) : 48
• Length (in) : 93
Polaris Sportsman Driveline
• Rear Unlocking Differential : No
• Driveline Type : Selectable 4X2 / 4X4
Polaris Sportsman Capacities
• Fuel Capacity (gal) : 6
Polaris Sportsman Front Suspension
• Front Travel (in) : 8.2
• Front Suspension Type : McPherson Strut
Polaris Sportsman Rear Suspension
• Rear Travel (in) : 8.8
• Rear Suspension Type : Independent
Polaris Sportsman Seat Specifications
• Seat Height (in) : 34
• Number Of Seats : 2
Polaris Sportsman Brakes
• Rear Brake Type : Hydraulic Disc
• Front Brake Type : Hydraulic Disc
Polaris Sportsman Tires
• Rear Tire (Full Spec) : 25 X 11-10
• Front Tire (Full Spec) : 25 X 8-12
Polaris Sportsman Price
MSRP : $8199
Warranty (Months) : 6
