Test drove a 500 tonight and two things were wrong. One the rpm did not work and the other is when you drove it down the road a battery light sign came on and flashed but only when you drove it. Any ideas before i think of buying it. Thanks
Problem sounds electrical. Could be as simple as corrosion or problems with the ECU or stator. Good luck.
I agree, at least a few hundred IF you can do the work yourself. It will take a little while to even narrow down what it is and shops charge big money per hour.
In other words, the other posters nicely said....... Keep looking, don't buy that issue machine!!
