I have 1 of the 15amp fuses (it has a solid red and a red/blk wire going to it) above the right front tire that blows immediately when key switch is turned to on position
The red/blk wire goes from the key switch to the LH handlebar switch - unplug the switch an see if it blows the fuse - if it does there is a short in the red/blk wire between the key switch and the LH switch
thank you very much
latebird I unplugged the LH switch and the fuse did not blow , so I replaced the switch and the fuse still blows as soon as the key is turned to the on position
I have traced wires and I am not seeing anything shorted
