I have a 2008 sportsman 500 efi. Im having some problems and I cant figure them out.
Here's the list
1. Battery light and speedo needle are flashing as soon as I start it.
2. Clock, miles, hours reset after the atv has been turned off for a couple minutes
3. Check engine light is not on but when I do a diag check codes 42 and 58 flash.
4. The speedo gauge shows .7 for voltage
And here's what i've done to try and fix the problems
1. Bought brand new battery and let it slow charge overnight and installed it.
2. For the codes 42 and 58, bought a new ect sensor even though the old one tested good. Check ohms on the ect wires. Checked for short to grounds. Everything has tested good.
3. Tested the ohms on the stator and it tested good.
4. With the engine running the battery reads 14.xx volts with my meter
Any help would be appreciated, I've downloaded a service manual and have been following it and the wiring schematics on it but have yet to figure out the problems. I don't know if I have one problem or multiple problems. I bought the bike wrecked and have been rebuilding it. The bike runs great, I rode it all last weekend but i'm trying to iron out the last few details.
Here's the list
