Having problems with the 20amp fuses popping NEED HELP!!! Was running and it just stoped, replaced battery with a new polaris battery. Installed battery same thing, replace starter with a new one same thing. If i have both 20amp fuses in the main and accy it will pop one, so i only put one in the main and it started right up and stayed running. If i put one in the accy and turn the key it will pop the main or accy fuse. So now i just have one in the main. Could the winch be causing this? Has any one had this problem? pleas let me know thanks. Its a 2008
take the fuse block off, turn it over and make sure wires are plugged in tight, have also seen broken wires around steering stem, they get the wires too tight from factory and when you turn it pulls on them, eventually breaking them, kind of a pain to find , have to take front plastic off take headligt pod apart, cut all zip ties from wire loom and take wires out of loom so you can see all of them.
