When I am just cruising at about 3500-4000 rpm there is a grinding or clicking noise coming from either the front axle or the front of the engine, you really can't tell. Is this common or something that needs to be checked out?:wizard:
I have the same machine it is normal to have drive shaft lash or gear lash you mostly hear it going downhill a clunking noise, I know it is iratating !! you should not hear it with power applied only when you let up or cruising. I hope this helps dealer will tell you it is normal !!
Thats the only time it does it, when you let off through that range, it kind of sounds like a locker trying to engage on the roll. Thanks for the input
