1 - 1 of 1 Posts
Good Day, in reverse on flat ground it will move properly but as soon as it has to work a bit (sandbags behind the front tires or even a slight incline), it will stop going, with a loud chattering sound.
Forward this does not happen at all.
So now I've pulled the transmission-rear diff combo out, looked inside, and so far can see the main silent chain is maxed out. (Tensioner wore a bit too) so those need changing.
Reverse chain has a bit of play, figure I'd change it too.
Any ideas what else to look at or change.
I'm going to try and recreate the problem and hopefully see what the tranny is doing.
1 - 1 of 1 Posts
