My battery in 2008 Sportsman Touring needs to be replaced. Any tips on how to go about it. The battery is stuck up in the front.
If its like my 06 x2, you remove the seat and the right side panel, and work throught there. I remove the strap, then the positive lewd, then pull the battery out far enough to remove the negative lead, and remove the battery. If you have a twin, I think there is a heat shield that has to come off first.
Sean
I like to attach a handle to the studs. Just be SURE IT IS NON METALLIC!!! ;)
