1 - 2 of 2 Posts
This winter a strange problem has started with 550. Cold weather first start of the morning, starts right up , maybe -15 or -20F.. No problem. Run it a bit pulling sled out ice fishing, shut it off , will not restart after maybe 10 min. of sitting there. Need to let it sit for at least 2 hours before restarts. Runs perfect. Doesnt do it everytime but most times. Took it to dealer he says they have 3 550s out doing the same thing. Cant figure it out. He said check and see if it is getting spark when acting up, so I did and it isnt getting spark. Again, below 0 conditions. It is the original battery, could it be that? turns over fine, but will run low very quick. I can hear the fuel pump priming. Weather warmed up and took it for ride, shut it off, started right up after sitting there. Any ideas? Thanks
1 - 2 of 2 Posts
