2009 Polaris Outlaw 525 S
2676 Views 0 Replies 1 Participant Last post by  Prddave
Specifications
Engine
• Engine Type: Single-Cylinder
• Displacement (cc): 510
• Cylinders: 1
• Compression Ratio: 11:1
• Engine Stroke: 4-Stroke
• Starter: Electric
Transmission
• Transmission Type: Manual
• Number Of Speeds: 5
• Primary Drive (Rear Wheel): Chain
• Reverse: Yes
Driveline
• Driveline Type: 4X2
• Rear Unlocking Differential: No
Dimensions
• Length (in): 71.5
• Width (in): 47.5
• Height (in): 44.3
• Wheelbase (in): 50.5
• Ground Clearance (in): 5
Front Suspension
• Front Suspension Type: Double A-Arm
• Front Travel (in): 10
Rear Suspension
• Rear Travel (in): 11
• Rear Suspension Type: Independent
Capacities
• Fuel Capacity (gal): 3
Seat Specifications
• Seat Height (in): 31.3
• Number Of Seats: 1
Brakes
• Front Brake Type: Dual Hydraulic Disc
• Rear Brake Type: Hydraulic Disc
Weight
• Dry Weight (lbs): 369
Tires
• Front Tire (Full Spec): Maxxis RAZR 21 X 7-10
• Rear Tire (Full Spec): Maxxis RAZR 20 X 10-9
Price
MSRP: $7399
Warranty (Months): 6
See less See more
1 - 1 of 1 Posts
1 - 1 of 1 Posts
