1 - 1 of 1 Posts
Specifications
Engine
• Displacement (cc): 196
• Cylinders: 1
• Compression Ratio: 9.2:1
• Engine Stroke: 4-Stroke
• Starter: Electric / Kick
• Engine Type: Single-Cylinder
Transmission
• Primary Drive (Rear Wheel): Shaft
• Reverse: Yes
• Transmission Type: Continuously Variable (CVT)
Driveline
• Rear Unlocking Differential: No
• Driveline Type: 4X2
Dimensions
• Wheelbase (in): 45
• Ground Clearance (in): 5.7
• Length (in): 65
• Width (in): 42
• Height (in): 42
Front Suspension
• Front Travel (in): 7
• Front Suspension Type: Double A-Arm
Rear Suspension
• Rear Suspension Type: Swing Arm
• Rear Travel (in): 6.5
Brakes
• Rear Brake Type: Drum
• Front Brake Type: Dual Hydraulic Disc
Capacities
• Fuel Capacity (gal): 2.5
Seat Specifications
• Seat Height (in): 32
• Number Of Seats: 1
Weight
• Towing Capacity (lbs): 300
• Dry Weight (lbs): 395
Tires
• Front Tire (Full Spec): Maxxis 21 X 7-10
• Rear Tire (Full Spec): Maxxis 20 X 10-9
Price
MSRP: $3299
Warranty (Months): 6
1 - 1 of 1 Posts
