1 - 1 of 1 Posts
Specifications
Engine
• Cylinders: 1
• Starter: Electric / Pull
• Engine Stroke: 4-Stroke
• Engine Type: Single-Cylinder
• Displacement (cc): 299
Transmission
• Reverse: Yes
• Transmission Type: Continuously Variable (CVT)
• Primary Drive (Rear Wheel): Shaft
Dimensions
• Length (in): 72
• Width (in): 45
• Height (in): 45.5
• Wheelbase (in): 46
• Ground Clearance (in): 8
Driveline
• Driveline Type: Selectable 4X2 / 4X4
• Rear Unlocking Differential: No
Front Suspension
• Front Suspension Type: McPherson Strut
• Front Travel (in): 7
Rear Suspension
• Rear Suspension Type: Independent
• Rear Travel (in): 8
Capacities
• Fuel Capacity (gal): 4.5
Seat Specifications
• Seat Height (in): 32
• Number Of Seats: 1
Weight
• Dry Weight (lbs): 550
• Towing Capacity (lbs): 750
Brakes
• Front Brake Type: Hydraulic Disc
• Rear Brake Type: Hydraulic Disc
Tires
• Rear Tire (Full Spec): 22 X 10-12
• Front Tire (Full Spec): 22 X 7-12
Price
Warranty (Months): 6
MSRP: $4999
1 - 1 of 1 Posts
