Specifications
Engine
• Engine Stroke: 4-Stroke
• Starter: Electric / Pull
• Engine Type: Single-Cylinder
• Displacement (cc): 329
• Cylinders: 1
• Compression Ratio: 9.2:1
Transmission
• Reverse: Yes
• Transmission Type: Continuously Variable (CVT)
• Primary Drive (Rear Wheel): Chain
Dimensions
• Ground Clearance (in): 5.5
• Length (in): 75
• Width (in): 46
• Height (in): 46
• Wheelbase (in): 49.5
Driveline
• Driveline Type: 4X2
• Rear Unlocking Differential: No
Front Suspension
• Front Suspension Type: McPherson Strut
• Front Travel (in): 6.7
Rear Suspension
• Rear Suspension Type: Swing Arm
• Rear Travel (in): 9
Capacities
• Fuel Capacity (gal): 3.3
Seat Specifications
• Seat Height (in): 34
• Number Of Seats: 1
Weight
• Dry Weight (lbs): 505
• Towing Capacity (lbs): 850
Brakes
• Front Brake Type: Hydraulic Disc
• Rear Brake Type: Hydraulic Disc
Tires
• Front Tire (Full Spec): 23 X 7-10
• Rear Tire (Full Spec): 22 X 11-10
Price
MSRP: $4099
Warranty (Months): 6
