The 90 will turn over but not fire when brake is off,when applied it won't do anything. Brake light works but nothing else. Checked all connections and wires don't know where to go next.
I used to own a 2010 Sportsman 90. If I remember correctly, the brake lever had to be pulled for the starter to engage. Is it possible the starter engagement wire(s) that pass through the brake switch got reversed somehow? Or somehow crossed with the kill switch? Also make sure the throttle cable is adjusted to where the end of the lever moves only 1/16" to 1/8" when at idle.
I have to ask since I've done it before. Is the fuel petcock in the ON or RES position?
Stew
Checked the fuel switch and the run switch first,because I've done both myself. The brake has to be pulled for it to fire,the brake light comes on which makes me think the wires are OK but I couldn't get it open to check inside , going to try again today,I'll let you know how that goes. Thanks.
