Hey everyone i am new to the site but have looked at allot of post!!
I was wondering if anyone knew whats the biggest tire that would fit on a 2009 sportsman 800efi? Without lift or moving A-Arms.
I am looking at 30" silverback X-lites or atleast X-Lites but what size will fit?
Thank you in advance
Normally 29.5-30" Tires would have slight clearance issues(Minor Rubbing) but the X-Lites from the reviews I have seen run small. With that in mind you should not rub with those tires. I will say though you will have to crank the rear springs on your bike as too much compression and they may rub some. Stiffening the springs will keep that from happening.
I'm running 30x 9x14 silverbacks all around on my 14 800 with no lift and stock a arms you will need axles first day I put these tires on I broke both front axles and upgraded to rhinos and have had good luck with those
