1 - 10 of 10 Posts
2009 sportsman 400 4x4 problem
Hello everyone. I am new here so bare with me. I just recently bought a 2009 sportsman 400 ho and I am having problems with my front left wheel spinning in awd. The cv joint shaft slipped out of the differential because of the clip so I replaced it. The awd still won't work for the front left wheel. Any suggestions??
Thanks for any help
Put the atv tires in the air and remove the bad axle. Have someone spin the tires, SLOWLY, and see if the differential is spinning. If not its your axle.
Yes, remove the axle from the diff and watch to see if the diff splines are spinning while the bike is running. If they do then you will know that the problem is with the axle.
You can get the whole output section of the front gear case from the dealer and replace it. Or you can find a used diff and swap it out. P/N 3234531 and retails at about $170
1 - 10 of 10 Posts
