High gear is getting very little to no power, once in a while it will catch & go but mostly just barely moves. If i put it in Low everything works perfect. Wouldnt a worn belt show some loss of power when in Low gear also? Or does High gear start losing power before Low gear with a wearing belt? Thanks
i would check the buttons in your secondary clutch
And you are correct, belt problems are indeed more noticeble in high gear.
