I found the easy way to get to the front top a-arm fittings is using a 10 inch set of needle nose vise grips and working from the other side. It is best also to have the wheels off. Hope this helps some of as it did me as I was really struggling to get to these 4 fittings.
good idea
i have a grease gun with a solid pipe on it and another with the rubber hose only use the solid one for those 4 spots
I had to use a solid extension as well to get to those fittings. I had to take the front wheels off to get to them.
