Specifications
Engine
• Starter: Electric
• Engine Type: Single-Cylinder
• Displacement (cc): 510
• Cylinders: 1
• Compression Ratio: 11:1
• Engine Stroke: 4-Stroke
Transmission
• Reverse: Yes
• Transmission Type: Manual
• Number Of Speeds: 5
• Primary Drive (Rear Wheel): Chain
Driveline
• Driveline Type: 4X2
• Rear Unlocking Differential: No
Front Suspension
• Front Suspension Type: Double A-Arm
• Front Travel (in): 10
Rear Suspension
• Rear Suspension Type: Independent
• Rear Travel (in): 10
Dimensions
• Ground Clearance (in): 5
• Length (in): 71.5
• Width (in): 47.5
• Height (in): 44.3
• Wheelbase (in): 50.5
Seat Specifications
• Seat Height (in): 31.3
• Number Of Seats: 1
Brakes
• Front Brake Type: Dual Hydraulic Disc
• Rear Brake Type: Hydraulic Disc
Weight
• Dry Weight (lbs): 369
Capacities
• Fuel Capacity (gal): 3
Tires
• Front Tire (Full Spec): Maxxis RAZR 21 X 7-10
• Rear Tire (Full Spec): Maxxis RAZR 20 X 10-9
Price
MSRP: $7399
Warranty (Months): 6
