1 - 1 of 1 Posts
Specification
Engine
• Engine Stroke: 4-Stroke
• Engine Type: Single-Cylinder
• Displacement (cc): 298
• Cylinders: 1
• Starter: Electric / Pull
Transmission
• Transmission Type: Continuously Variable (CVT)
• Primary Drive (Rear Wheel): Shaft
• Reverse: Yes
Dimensions
• Width (in): 44
• Height (in): 44.5
• Wheelbase (in): 46
• Ground Clearance (in): 8
• Length (in): 72
Brakes
• Front Brake Type: Hydraulic Disc
• Rear Brake Type: Hydraulic Disc
Front Suspension
• Front Suspension Type: McPherson Strut
• Front Travel (in): 7
Rear Suspension
• Rear Travel (in): 8
• Rear Suspension Type: Independent Double A-Arm
Capacities
• Fuel Capacity (gal): 4.5
Seat Specifications
• Seat Height (in): 32
• Number Of Seats: 1
Weight
• Dry Weight (lbs): 550
• Towing Capacity (lbs): 750
Driveline
• Driveline Type: Selectable 4X2 / 4X4
• Rear Unlocking Differential: No
Tires
• Front Tire (Full Spec): 22 X 7-12
• Rear Tire (Full Spec): 22 X 10-12
Price
MSRP: $4999
Warranty (Months): 6
1 - 1 of 1 Posts
