2010 Polaris Sportsman 500 H.O. Touring
8736 Views 0 Replies 1 Participant Last post by  Prddave
Specifications
Engine
• Engine Type: Single-Cylinder
• Displacement (cc): 498
• Cylinders: 1
• Compression Ratio: 10:2
• Engine Stroke: 4-Stroke
• Starter: Electric
Transmission
• Primary Drive (Rear Wheel): Shaft
• Reverse: Yes
• Transmission Type: Continuously Variable (CVT)
Dimensions
• Wheelbase (in): 57
• Ground Clearance (in): 11
• Length (in): 86
• Width (in): 48
• Height (in): 48
Front Suspension
• Front Travel (in): 8.2
• Front Suspension Type: McPherson Strut
Rear Suspension
• Rear Suspension Type: Independent Double A-Arm
• Rear Travel (in): 8.8
Capacities
• Fuel Capacity (gal): 5.3
Seat Specifications
• Seat Height (in): 33.8
• Number Of Seats: 2
Weight
• Towing Capacity (lbs): 1225
• Dry Weight (lbs): 740
Polaris Sportsman® Driveline
• Rear Unlocking Differential: No
• Driveline Type: Selectable 4X2 / 4X4
Brakes
• Rear Brake Type: Hydraulic Disc
• Front Brake Type: Hydraulic Disc
Tires
• Front Tire (Full Spec): 25 X 8-12; 489
• Rear Tire (Full Spec): 25 X 11-12; 489
Price
MSRP: $7399
Warranty (Months): 6
See less See more
1 - 1 of 1 Posts
1 - 1 of 1 Posts
