1 - 2 of 2 Posts
2010 Polaris Sportsman H.O. 500
Specification
Engine
• Engine Type: Single-Cylinder
• Displacement (cc): 498
• Cylinders: 1
• Compression Ratio: 10:2
• Engine Stroke: 4-Stroke
• Starter: Electric
Transmission
• Transmission Type: Continuously Variable (CVT)
• Primary Drive (Rear Wheel): Shaft
• Reverse: Yes
Dimensions
• Height (in): 48
• Wheelbase (in): 50.5
• Ground Clearance (in): 11.3
• Length (in): 83
• Width (in): 48
Front Suspension
• Front Suspension Type: McPherson Strut
• Front Travel (in): 8.2
Rear Suspension
• Rear Travel (in): 9.5
• Rear Suspension Type: Independent Double A-Arm
Capacities
• Fuel Capacity (gal): 4.1
Seat Specifications
• Number Of Seats: 1
• Seat Height (in): 33.8
Weight
• Dry Weight (lbs): 696
• Towing Capacity (lbs): 1225
Driveline
• Driveline Type: Selectable 4X2 / 4X4
• Rear Unlocking Differential: No
Brakes
• Front Brake Type: Hydraulic Disc
• Rear Brake Type: Hydraulic Disc
Tires
• Front Tire (Full Spec): 25 X 8-12; 489
• Rear Tire (Full Spec): 25 X 11-12; 489
Price
MSRP: $5999
Warranty (Months): 6
I have a 2010 sportsman 500ho with about 500 miles on it and now im bloowing coolant out of exhaust, no coolant in the oil tho, so cauld it be a blowen head gasket.
1 - 2 of 2 Posts
