This is a update from my earlier post (nov, 12).
As stated in that post my sportsman pulls hard intermittently. I have done the flushing of the front diff as suggested. Don't know how to systematically check for shorts or poor grounds.
What is for sure, water has a definite affect. If I go crawling through a waterhole that is up to or slightly above the floor boards the ATV becomes very difficult to steer in 2 or awd?
Any ideas how to narrow this down would be appreciated
:beer:
Is water reaching the wire connector to the front differencial? If so pup it apart and apply dielectric grease, to keep it water tight. Guessing water may be creating a short in the AWD electrical system for you? :dunno:
If you don't know how to check / trouble shoot it..... it may be better for you and the machine to take it in to a trusted small engine shop or Popo dealer.
Discussion Starter · #4 ·
MustBeNice:I can definitely check the connector and follow it back as far as I can. Where abouts does it connect to the front diff? Will it show me in the manual?
Williamboss; Thanks for the download offer. I do have a manual!
Here is my limited knowledge trouble shooting. When I do find the connector, can I disconnect it all together and see if the problem goes away water or no water?
Thanks for your help guys
