I want to be able to start my 2011 500 without holding in the brake lever or putting it in neutral. My 2004.5 400 is this way from the factory. I can hear a switch click somewhere but haven't found it yet, if I bypass the switch and solder the wires together will the brake light be on all the time. Can someone explain how I could do this and where this switch is located. There are no wires go up the handle bar to the brake.
Well the choke on this machine is spring loaded and will not stay out, so it is almost impossible to turn the key, hold the choke out and hold the brake in at the same time. Yes I know I could put it in park, neutral or lock the brake on but it is just a pain in the arse especially when I am so used to just starting my older sportsman and going
I have a 2011 500 as well and the choke stays out by itself I think there is an adjustment on the choke knob to stiffen it up so choke does not retract when you let go of it. Hope this helps.
Has anyone else had problems with the 1 way bearings failing multiple times?
Last May I was in Hatfield Mccoy and I was coasting down a steep hill letting the EBS do it's it's thing, next thing i know there's a loud squeal and the quad starts free wheeling. I get to a landing on the hill and...
In order to minimize water entry and extend the life of the rear lower a-arm bushings in my 2006 Sportsman 450, I installed grease zerks in the bushing housings. The zerks must be installed dead center in the housings, since there is only about a tenth of an inch space between the bushings.
Hey,
Anyone got a copy of the 2000-2008 Sportsman 90 Service Manual
in PDF they can send to me?
I got one and it ha no key switch and the wiring in the "dash" is cut up.
Thanks!
Mike
I installed a led light bar with the Polaris factory relay and after getting it all wired up I turned the key over once to make sure the lights worked and all was good. I checked it again and the quad is totally dead, no powering up or turning over. I did notice that the ground and power wire...
Hello, I am glad to find this forum about Polaris rides, thanks for having me here!
I have a 2004 700 Sportsman Carbureted that is Blue and Silver with under 1,000 miles on it! I use it as a tool on my property to plow, get firewood and my wife to ride once in awhile.
The light bulbs are...
