When the handle bars are turned left or right the atv speeds up. Engine light has comes on with code of 520194 3 which is Throttle Safety Signal voltage too high. when engine starts unable to shift gear leaver as engine is running to fast. I can pull or push the throttle body cable and change the engine speed. What is the fix for this issue.
