1 - 1 of 1 Posts
I have a problem where after I start xp it runs great for 2 mins then it will stall or if I hold throttle it will stay running but will be very rough. I will shut er down, wait a minute then restart and it will run good again for a couple minutes. I adjusted throttle gap and it was fine.You can set a clock to it...
How can this be so perfect timing. Is the computer shot? I brought it in the dealer and the damb thing ran good for them . They looked it all over ,put it on there tester too.
Sometimes it will set a error code of 102 4 which is a map sensor .
Can someone PLEASE HELP.. I need this thing going for a ride this weekend and I don't want a polaris to be the P.O.S. of you know what I meen. Thanks for everyones help..
1 - 1 of 1 Posts
