I have a 2011 sportsman 850xp It has a highlifter 3 inch lift, 14inch msa diesels and 32x10x14 silverbacks. The front has turner axles and the rears are rhino brand axles. I recently replaced all the wheel bearings but when i lift the rear end up the left rear wheel has a lot of play in it. I replaced the A Arm bushings and it still moves. What could be causing this has anyone experienced a similar problem?
^^x2^^
The bearings are in the knuckle, the knuckle is bolted at the top and bottom, to the a-arms. The bushings are shot in the knuckles.
i have replaced the bushings in the knuckle it helped a little. It seems like the bearing is moving in the knuckle or the hub is moving inside the bearing. I checked specs on the axle nut and it was within spec this is what has me confused.
