I have a 2011 polaris sportsman xp 850. When I turn the key that's all I get is a clicking sound. The clicking sound is the gear moving over but the starter does not run. Battery voltage is good. If I pull the starter out and bench test it it is fine. If I put voltage on the small wire on the starter cyclinoid, the quad starts and runs fine. I thought it was the starter relay inside the fuse box. Replaced it but still have the same problem. If I put a jumper wire in place of ths starter relay in the fuse box, the quad starts fine. What am I missing? Any suggestions? I don't believe it's the ignition switch, starter relay, or starter.
Will it start in gear with the hand brake squeezed?
Welcome to the board!
