The 2011 Polaris Outlaw® 525 IRS ATV is race proven & purpose-built for trail riding. This KTM®-powered, fast-accelerating stock sport quad is ideal for high-performance ATV trail riding and ATV racing.
Key features are:
•510cc KTM® Racing Engine
•PRO Independent Rear Suspension
(PRO IRS)
•Fox Podium X® Racing Shox
•Maxxis® RAZR® Radial Tires
Features:
Pro Independent Rear Suspension with front and rear Fox Podium®1 X Shox.
Transmission
5-Speed manual transmission
with reverse and Magura® clutch for smooth operation and no fade.
Powerful Engine
Powered by a Lightweight KTM®1 Engine
Tires
Maxxis® RAZR®1 Radial Tires
Stong A-Arms
Forged Rear Aluminum A-Arms and Upper Control Arms
Specifications
MSRP $7,699
Engine
Engine Type 4-Stroke KTM Racing, Single Cylinder
Displacement 510cc
Fuel System Carbureted
Cooling Liquid
Drivetrain
Transmission/Final Drive Hydraulic Manual Clutch/Manual Shift 5-Speed with Reverse; 520 O-Ring Chain
Drive System 2WD
Engine Braking System/ Active Descent Control Not Equipped
Suspension
Front Suspension Dual A-Arm with 10" (25.4 cm) Travel
Rear Suspension Pro IRS with 10" (25.4 cm) Travel
Brakes
Front/Rear Brakes Dual Hydraulic Disc with Dual-Piston Front Calipers
Parking Brake Lockable Hand Lever
Tires Wheels
Front Tires / Model 21 x 7-10; Maxxis RAZR Radial
Rear Tires / Model 20 x 10-10; Maxxis RAZR Radial
Wheels Spun Aluminum
Dimensions
Wheelbase 50.5" (128.3 cm)
Dry Weight 389 lb (176.5 kg)
Overall Vehicle Size (LxWxH) 71.5 x 47.5 x 45" (181.6 x 120.7 x 114.3 cm)
Ground Clearance 11" (27.9 cm)
Seat Height 32" (81.3 cm)
Capacities
Fuel Capacity 3 gal (11.4 L)
Features
Lighting Dual Hi/Low Beam (55w/60w); Single Rear Brakelight/Taillight
Instrumentation N/R Light, Hi-Temp Light
