1 - 1 of 1 Posts
2011-Polaris-Phoenix200aThe 2011 Polaris Phoenix 200 ATV is our entry-level sport ATV. This value-priced model is ideal for ATV trail riding and recreational riding.
Key features are:
• 196 cc air-cooled engine
• Dual A-Arm Front Suspension
• Long-Travel Rear suspension
• Automatic Transmission
Features
Designed For 14 And Up
T Category. For operators age 14 or older with adult supervision or operators age 16 or older
Transmission
Automatic PVT transmission with forward, neutral, and reverse
Front Suspension
Dual A-Arm front suspension reduces kickback for better steering control.
Drive
The Phoenix features two-wheel drive system
Suspension
Long travels suspension gives you 6.5" of rear suspension travel
Specifications
MSRP $3,499
Engine
Engine Type 4-Stroke Single Cylinder
Displacement 196cc
Fuel System Carbureted
Cooling Air
Drivetrain
Transmission/Final Drive Automatic PVT F/N/R; Shaft
Drive System 2WD
Engine Braking System/ Active Descent Control Not Equipped
Suspension
Front Suspension Dual A-Arm with 7" (17.8 cm) Travel
Rear Suspension Mono-Shock Swingarm with 6.5" (16.5 cm) Travel
Brakes
Front/Rear Brakes Front Hydraulic Disc; Rear Mechanical Drum; (Independent front/rear brake levers plus rear foot brake)
Parking Brake Lockable Hand Lever
Tires Wheels
Front Tires / Model 21 x 7-10; Duro
Rear Tires / Model 20 x 10-9; Duro
Wheels Stamped Steel
Dimensions
Wheelbase 45" (114.3 cm)
Dry Weight 395 lb (179 kg)
Overall Vehicle Size (LxWxH) 65 x 42 x 42" (165.1 x 106.7 x 106.7 cm)
Ground Clearance 5.7" (14.5 cm)
Seat Height 32" (81.3 cm)
Capacities
Fuel Capacity 2.5 gal (9.5 L)
Hitch Towing Rating 300 lb (136.1 kg) - with Accessory Hitch
Hitch/Type Accessory/Drawbar
Features
Lighting Single Hi/Low Headlight; Single Rear Brakelight/Taillight
Instrumentation N/R Light, Hi-Temp Light
1 - 1 of 1 Posts
