1 - 2 of 2 Posts
I have a polaris sportsman 500 ho 2011 model...an I was wondering if anyone had any issues with just cutting off when it wanted to like in a hole or something..I can fly down the road then when I slow down to come to a stop sometimes it will just cut off but fire rite back up fine..........an also one other ? The line going from the front of the engine to a inline filter then to the air box I think its the oil resvoir hose..anyway it leaks around the clamp at the engine so I took the hose off an cleaned it an put a different clamp on it an it still leaks oil has anyone ever had any of these problems ...thanks for yalls help
:Had a key ring on my key and when I turn the steering it would cut out due to ring hitting the gas cap. The cable going to the throttle control override switch was out of adjustment and that caused the machine to cut out. Had it reset to proper setting and has worked fine since. Hope this helps. :veryhappy:
1 - 2 of 2 Posts
