not sure what to do to fix the problem of my wheeler coming out of high gear when i give its some gas the the grinding happens:str::str::str::str::str:
I've had the Polaris Wireless Winch Remote for a couple of years now, and it has worked pretty well. I went to use it the other day and I noticed that the little red light wasn't working. Pretty soon the remote didn't work at all. I figured that the battery probably had crapped out so I bought a...
I just got done with a complete 570 rebuild from the crank up. The one area I had difficulty was the removal and reinstallation of the crank. The old put one part in the freezer and heat the other part did not work on this engine! I had a Polaris dealer kind enough to loan me his special...
I,m new here hoping for some answers. My 06 Ranger 700EFI will not accelerate. Idle is ok but rough. Plugs were fouled black but new plugs did not help TPS was replace five years ago. Injectors were checked and cleaned a year ago. Fuel pressure is about 36PSI and holds constant on acceleration...
