The 2011 Polaris Sportsman Touring 550 EPS ATV is the industry’s most comfortable ATV, and the ideal 2-person ATV. For 201: more rear suspension travel, larger fuel tank and more.
Key features are:
•549cc SOHC EFI Engine
•Adjustable Rear Comfort Ride Seat Suspension(TM)
•Electronic Power Steering
(EPS)
•Rolled Independent Rear Suspension (IRS)
Features:
First-Ever Seat Suspension
The exclusive Comfort Ride Seat Suspension™ features a spring beneath the passenger seat, adding to the 10.25" of travel on the legendary Polaris IRS. Our IRS is angled rearward for even greater comfort and to reduce squat while accelerating.
Ergonomics For Your Comfort
With the engine rotated 90 degrees, riders enjoy 33% wider floorboards and narrower vehicle width at the knees (3.25") and ankles. The narrower seat reduces leg fatigue and increases rider comfort.
Electronic Power Steering (EPS)
The smoothest, most responsive power steering available, with 30% more power assist than the leading competitor, plus Variable Assist for easier steering at lower speeds and greater responsiveness at higher speeds.
Strong, Powerful Engine
550 Single, SOHC, 4 valves
Standard Front Storage And New! Rear Accessory Box
Large front storage has 8.2 gallons of capacity. For more storage, remove the passenger seat and new Lock & Ride hand grips and replace it with an optional Lock & Ride accessory box with 2.5-gallon capacity.
Anti-Kickback Steering
Placing the steering axis near the neutral center of the tire and having the long Dual A-Arm Front Suspension dramatically reduces kickback and minimizes rider fatigue that comes with jolts to the handlebars from trail and ground obstacles.
On-Demand True All Wheel Drive (AWD)
Still the best automatic 4x4 system out there, the AWD engages all four tires when the rear wheels slip and you need more forward traction. Reverts back to 2WD when you don’t.
Active Descent Control (ADC) And Engine Braking System (EBS)
Work together to monitor and control downhill braking to give you optimum control and smooth, even deceleration during descents.
Specifications
MSRP $9,299
Engine
Engine Type 4-Stroke SOHC Single Cylinder
Displacement 549cc
Fuel System Electronic Fuel Injected
Cooling Liquid
Drivetrain
Transmission/Final Drive Automatic PVT P/R/N/L/H; Shaft
Drive System On-Demand True AWD/2WD
Engine Braking System/ Active Descent Control Standard/Standard
Suspension
Front Suspension Dual A-Arm 9" (22.9 cm) Travel
Rear Suspension Dual A-Arm, Rolled 10.25" (26 cm) Travel
Brakes
Front/Rear Brakes Single Lever 4-Wheel Hydraulic Disc with Hydraulic Rear Foot Brake
Parking Brake Park in Transmission/Lockable Hand Lever
Tires Wheels
Front Tires / Model 26 x 8-14; Maxxis
Rear Tires / Model 26 x 10-14; Maxxis
Wheels Cast Aluminum
Dimensions
Wheelbase 57" (144.8 cm)
Dry Weight 765 lb (348 kg)
Overall Vehicle Size (LxWxH) 86.5 x 47.6 x 58.25" (219.7 x 120.9 x 147.9 cm)
Ground Clearance 11.25" (28.5 cm)
Seat Height 35.75" (90.8 cm)
Capacities
Fuel Capacity 5.25 gal (19.9 L)
Front/Rear Rack Capacity 120 lb (55 kg)/240 lb (110 kg)
Hitch Towing Rating 1,500 lb (680.4 kg)
Unbraked Trailer Towing Capacity "*Based on EU Directive 76/432/EC 1,995 lb (905 kg)
Hitch/Type Standard/1.25" Receiver
