The 2011 Polaris Sportsman X2 550 is the most versatile ATV on the planet. The perfect utility ATV in rear-cargo mode and touring ATV in 2-Up mode. New: more seat foam increases passenger comfort.
Key features are:
•549cc SOHC EFI Engine
•1-Up & 2-Up Versatility In Seconds
•On-Demand True All-Wheel Drive (AWD) With Versatrac Turf Mode
•Anti-Kickback Steering
Features:
1-Up And 2-Up Versatility In Seconds
Switches from work to play in seconds. Rear dump box features a 400-lb. capacity and, in three easy steps, goes from 1-up work mode to 2-up play mode in less than 10 seconds.
New! Passenger Seat Design
We added 21% more seat foam for a total of 4" of seat padding, to increase passenger comfort on those long rides.
Huge Front Storage
Huge Front Storage Box With 8.2-Gallon Storage Capacity
True AWD keeps you moving, automatically engaging all four wheels when you need more forward traction and reverting back to 2WD when you don’t. When in 2WD, the VersaTrac Turf Mode switch unlocks the rear differential for easier, tighter turns to minimize damage to sensitive terrain.
Placing the steering axis near the neutral center of the tire and having the long Dual A-Arm Front Suspension dramatically reduces kickback and minimizes rider fatigue that comes with jolts to the handlebars from trail and ground obstacles.
Active Descent Control (ADC) And Engine Braking System (EBS)
Work together to monitor and control downhill braking to give you optimum control and smooth, even deceleration during descents.
Roll Ed Independent Rear Suspension IRS
With 10.25" of suspension travel, our proven Rolled IRS is angled rearward to keep the ride smooth for you and your passenger and reduce squat while accelerating
Specifications
MSRP $8,999
Engine
Engine Type 4-Stroke SOHC Single Cylinder
Displacement 549cc
Fuel System Electronic Fuel Injected
Cooling Liquid
Drivetrain
Transmission/Final Drive Automatic PVT P/R/N/L/H; Shaft
Drive System On-Demand True AWD/2WD/VersaTrac Turf Mode
Engine Braking System/ Active Descent Control Standard/Standard
Suspension
Front Suspension Dual A-Arm 9" (22.9 cm) Travel
Rear Suspension Dual A-Arm, Rolled 10.25" (26 cm) Travel
Brakes
Front/Rear Brakes Single Lever 4-Wheel Hydraulic Disc with Hydraulic Rear Foot Brake
Parking Brake Park in Transmission/Lockable Hand Lever
Tires Wheels
Front Tires / Model 26 x 8-14; Maxxis
Rear Tires / Model 26 x 10-14; Maxxis
Wheels Stamped Steel
Dimensions
Wheelbase 57" (144.8 cm)
Dry Weight 799 lb (362.3 kg)
Overall Vehicle Size (LxWxH) 93.25 x 47.6 x 49.5" (236.8 x 120.9 x 125.73 cm)
Ground Clearance 11.25" (28.5 cm)
Seat Height 35.75" (90.8 cm)
Capacities
Fuel Capacity 5.25 gal (19.9 L)
Bed Box Dimensions (LxWxH) 37.5"x19.5"x6.5" (95x49.5x16.5 cm)
Front/Rear Rack Box Capacity 120 lb (55 kg)/400 lb (180 kg)
Hitch Towing Rating 1,500 lb (680.4 kg)
Unbraked Trailer Towing Capacity "*Based on EU Directive 76/432/EC 1,995 lb (905 kg)
Hitch/Type Standard/1.25" Receiver
Just got mine 2 weeks ago. Out the door @ $7616. I thought that was pretty good with an MSRP of $8999. I love this machine so far. My wife can't believe how comfortable it is to ride in the 2-up seat.
so far I have no complaints/ this thing goes wherever I point it.
Have had it a month now. Very happy that I did not get a touring. This thing is so easy to steer I will not miss the power steering.
