1 - 1 of 1 Posts
The 2011 Polaris Sportsman XP® 850 EPS ATV is built for extreme off-road performance. Our most powerful big-bore model, it’s ideal for trail riding, hunting, and is the perfect utility ATV.
Key features are:
•850cc SOHC Twin-Cylinder EFI Engine
•Electronic Power Steering (EPS)
•Rolled Independent Rear Suspension (IRS)
•1,500 lb. (680 kg) Towing Capacity
Features:
•Photo Realistic Polaris Pursuit® Camo
•14" Polaris Pursuit Camo Steel Wheels with Carlisle AT 489 II Tires
•Rear Work Lights
•Lock & Ride® Gun Scabbard
•2500 lb. Winch
•Rear Rack Extender
•Hand and Thumb Warmers
Specifications
MSRP $10,999
Engine
Engine Type 4-Stroke SOHC Twin Cylinder
Displacement 850cc
Fuel System
Electronic Fuel Injected
Cooling Liquid
Drivetrain
Transmission/Final Drive Automatic PVT P/R/N/L/H; Shaft
Drive System On-Demand True AWD/2WD
Engine Braking System/ Active Descent Control Standard/Standard
Suspension
Front Suspension Dual A-Arm 9" (22.9 cm) Travel
Rear Suspension Dual A-Arm, Rolled 10.25" (26 cm) Travel
Brakes
Front/Rear Brakes Single Lever 4-Wheel Hydraulic Disk with Hydraulic Rear Foot Brake
Parking Brake Park in Transmission/Lockable Hand Lever
Tires Wheels
Front Tires / Model 26 x 8-14; 489 II
Rear Tires / Model 26 x 10-14; 489 II
Wheels Cast Aluminum
Dimensions
Wheelbase 53" (134.6 cm)
Dry Weight 773 lb (351.4 kg)
Overall Vehicle Size (LxWxH) 83.25 x 47.6 x 50.75" (211.4 x 120.9 x 128.9 cm)
Ground Clearance 12" (30.5 cm)
Seat Height 37" (94 cm)
Capacities
Fuel Capacity 5.25 gal (19.9 L)
Front/Rear Rack Capacity 120 lb (55 kg)/240 lb (110 kg)
Hitch Towing Rating 1,500 lb (680.4 kg)
Unbraked Trailer Towing Capacity "*Based on EU Directive 76/432/EC 1,914 lb (868.2 kg)
Hitch/Type Standard/1.25" Receiver
1 - 1 of 1 Posts
